3_tons
Jan 20, 2023Explorer III
I’m definitely with Bigfootford, but my question is this..Are you using all four jacks simultaneously or just two at a time? Also, it’s not a common practice to use an electric drill unless your batteries are low or failing…Be advised that a Auto-Zone type carbon-pile load test is not always to be relied upon as a true representation of actual loading…If possible you could try measuring battery output (while under load) using a clamp-on ac-dc volt-current meter - make sure that your meter is ‘truly dc current capable’ and of sufficient amperage…A meter of this type is still cheaper than new batteries and should readily tell you what you need to know..
Also, when using meter in ‘dc mode’, be certain to position the meter in the proper current direction - follow carefully the meter’s instructions …
3 tons
3 tons
