ssthrd
Jan 20, 2023Explorer
It seems to me that you have checked all of your systems except for the jacks. I am definitely not an electrical expert, but it looks like they are the common denominator. Can you check the draw on each one individually?
You mentioned that you have exclusively used a drill to raise and lower the jacks, and you still have the same problem. Do you unplug the jacks when you use them manually? Do you have something else running all the time without you knowing it?
You have had the batteries load tested, and a shop expert (?) says that your converter is working as it should. What's left to check?
I'll let the ones here way smarter than me respond to my questions.
