wnjj
Jan 20, 2023Explorer II
bigfootford wrote:
Depending on the weight of your camper the amps needed for a 4500lb camera will be between 35-40 amps to raise the camper..
The OP said the batteries are drained from removing the camper, which makes even less sense. Other than the initial lift off the truck bed, most of the time the motors aren't even loaded when running to remove it.
