3_tons
Jan 20, 2023Explorer III
Dupa wrote:3 tons wrote:
I’m definitely with Bigfootford, but my question is this..Are you using all four jacks simultaneously or just two at a time? Also, it’s not a common practice to use an electric drill unless your batteries are low or failing…Be advised that a Auto-Zone type carbon-pile load test is not always to be relied upon as a true representation of actual loading…If possible you could try measuring battery output (while under load) using a clamp-on ac-dc volt-current meter - make sure that your meter is ‘truly dc current capable’ and of sufficient amperage…A meter of this type is still cheaper than new batteries and should readily tell you what you need to know..
Also, when using meter in ‘dc mode’, be certain to position the meter in the proper current direction - follow carefully the meter’s instructions …
3 tons
I am using all 4 jacks simultaneously. Maybe a little overly simplistic way of thinking about it (and also maybe a little out of my element here) but it seems like the same amount of power/energy is needed to raise/lower the camper, so whether you break it into pieces (1 or 2 at a time) or do it all at the same time (all 4 jacks) shouldn't matter all that much. If I'm wrong, and doing 1 or 2 at a time would help solve my problem, please let me know.
I only asked the question to aid with diagnostics from a distance (available current supplied…). Having said that, my personal preference (due to TC weight) is to operate only two jacks at time per each end (say, inch by inch…) - JMO
Sorry for any confusion :)
3 tons
