StirCrazy
Jan 24, 2023Moderator
Dupa wrote:
The batteries (2 x grp 24 wet cell deep cycle Interstates) were new when I bought the rig
the problem with these batteries is there only 81ish AH total, and to maintain there life you shouldnt use over 40 of thoes AH so with two batteries you have 80AH o play with. even time you use over 50% of the capacity you can weaken the battery. also leaving it plugged in can eveporate some of the water, so I am assuming your topping of the water the water level , unless there a maintanence free type. if you have ran them down quite often there is a good possibility you need new batteries, did everything work good when you go it in 2001?
Steve
44,070 PostsLatest Activity: Sep 18, 2026
