hertfordnc
Aug 08, 2015Explorer
Help- Ford Expi 5.4 not getting fuel
Not so much an RV question but i know the folks on this forum are quicker to provide good answers than the Ford Forums and I am in a jam.
Truck was running great then it stalled a light and would not restart.
I jumpered the fuel pump at the inertia switch and it still would not run.
Changed the fuel pump. No change. It gets enough fuel to cough and sputter, runs a little but never gets above idle.
COuld be fuel filter but in my experience a fuel filer will allow it to run fine until you load it. And I need the ford fuel line tool and the stores are not open yet.
So, where else can i look for a fuel flow problem?
Prior to this I got a code for "LEAN FUEL" - i fixed a vacuum leak and it went away. Then i got a code saying fuel was too rich. But the truck was still running fine.
My next move is to open the fuel line at the filter bu I dont think that's the problem.
