Community Alumni
Apr 04, 2018Not applicable
You can air the tires up to 51 PSI. Run the truck and trailer across a CAT scale. It's better to base your adjustments off of actual weights vs fender measurements. You can clearly see where the weight is moving with scale numbers.
44,071 PostsLatest Activity: Aug 30, 2026
