Yes, brake controller is being installed this afternoon
Yes, it has tow/haul feature
Yes, trans cooler was installed two weeks ago (although aftermarket)
Maybe, Gears will do because it's a light trailer and we live in flat land (Louisiana and Florida trips mostly). I'll re-gear prior to doing anything more strenuous.
bikendan wrote:
OP,
You obviously have a truck not equipped for towing a travel trailer.
It takes more than just converting a 4 pin to 7 pin.
How are you hooking up a brake controller?
Does it have the tow/haul feature?
Does it have the factory tow package Trans cooler?
Does it have the towing rear end ratio?
You have to match what comes in the factory tow package, to get the higher tow capacities.
