vjstangelo
Aug 14, 2019Explorer
agesilaus wrote:
OK in general I'd say that east of the Mississippi a gas engine is fine. Cheaper too. But once you hit the mountain states you will be sorry if you do not have a diesel. Diesels shine pulling loads up and down (engine brake) grades.
And as mentioned above do not buy a 3/4 ton, the one ton is slightly more money but it will pull much better. No different in the way they drive either.
I would recommend a newer 5 speed or 6+ speed transmission(s) if you go gas as the tow haul mode, while not a true Jake Brake, does very good using engine compression to manage steep down grades. FWIW we have a 22,000# GVWR Winnebago Class A on the F53 chassis with the 5R110 Torqshift 5 speed. A great combo.
