dezldog1's avatar
dezldog1
Help....advice on purchasing truck camper
Hi everybody,
Looking for some advice. We just sold our 33 LCDTS Silverback fifth wheel and are downsizing to a camper. We have a 2010 heavy duty 2500 diesel with Firestone air bags. We have taken a fancy to a...2000 Adventurer 90FWS EXT Camper.. We are going to view it at 10 a.m. tomorrow. Our truck is only a 6' 4" box but the fella said with the tailgate down we should be able to haul it. The previous owner apparently did. I think he said it's 2038 lb. I was just wondering if anybody else owns that same camper or similar to it and if you're happy with it. Also wondering what you are using to haul it with. Any bit of information you care to share with me would be greatly appreciated..
Thanking you in advance.
Regards
Jo
  • wnjj's avatar
    wnjj
    Explorer II
    The COG required to be in front of the rear axle isn’t so much a fact as a common suggestion. The manufacturers don’t agree.
  • work2much wrote:
    ykphil wrote:
    Two most important considerations when matching a truck to a TC are the truck's rated payload which should be equal to or higher than the total weight of the truck camper plus everything else in the bed (equipment, tools, fuel, water, etc.) and cab (driver, passengers, etc.), keeping in mind the weight posted on the TC might be underestimated. Nothing you can do or add to your truck such as air bags, stabilizers, etc. can change its payload. Second factor is the TC's centre of gravity which must be above or in front of your truck's rear axle. The rest is a question of preference.
    I guess I have been doing it wrong for almost 30 years. What is your truck and camper history and experience?
    Not here to argue about one's experience or history with trucks and TCs. I am simply stating two demonstrated facts, that truck payload and TC's COG in relation to the truck are important factors to consider when matching truck and TC.
  • Two most important considerations when matching a truck to a TC are the truck's rated payload which should be equal to or higher than the total weight of the truck camper plus everything else in the bed (equipment, tools, fuel, water, etc.) and cab (driver, passengers, etc.), keeping in mind the weight posted on the TC might be underestimated. Nothing you can do or add to your truck such as air bags, stabilizers, etc. can change its payload. Second factor is the TC's centre of gravity which must be above or in front of your truck's rear axle. The rest is a question of preference.
