BossCamper's avatar
BossCamper
HELP! Converter problems
Leaving tomorrow morning for a week camping.
This morning I find the converter is pooched.
It's a Parallax 7100
When I plug into 120 volt with battery disconnected, I get a one second flash of the lights (12 volt) in the trailer then nothing. (on maybe half of the circuits) other half is OK.
Of course, the circuits that power the refrigerator won't stay on.
If I connect the battery, everything works. All the 120 volt circuits and the 12 volt.
One thing, I don't hear any fan activity, but I guess that might be because there isn't enough power draw to heat it up.
I'm prepared (I think) to replace the converter in the campground .
Any quick hints or insights?
I'll be in and out to the trailer so if anyone answers, be paitint for a reply
Thanks in advance.
Loris
  • Volt meter time,
    verify 120 volt on both circuits coming in.
    Check battery voltages with unit plugged in and not plugged in.
    check for a fuse on the 12 volt line from one side of the converter, battery use may compensate and if you are charging, you should have no problems.
