NRALIFR
Dec 27, 2013Explorer
campermama wrote:
Ok I think it may be ok now.....can it be when you change the battery it needs to like reset itself? I let it sit for a while and now it seems to be working ok, at least for right now....
No, it sounds like the camper battery charge is low. Is the camper plugged in to shore power all the time? It takes a fully charged battery to operate all four jacks at once, especially if you're raising the camper. If the camper battery charge is low and you just plugged it in to shore power, it's going to take a little while before the battery is charged enough to use the jacks. You can cheat it a little with a low battery by just running one jack at a time.
44,056 PostsLatest Activity: May 04, 2014
