peirek
Nov 20, 2013Explorer
mbshock wrote:
Thanks, I found the fusebox above the tv cabinet once I knew what I was looking for. The fuse was good, also the fuses under the control panel are good in the rear of fridge. Also smelling the distinct odor of amonia. Can't be good.
Your assumption is correct. An ammonia smell in the back of the refrigerator is absolutely not good. Might look for some yellow discoloring to indicate the location of the leak. Before replacing the entire frig, check into companies that build replacement cooling systems. If you are handy, this would be a cheaper option.
