opnspaces wrote:
beemerphile1 wrote:
I figure our everyday camping gear with food and water exceeds 1,500.
1'500, that's a lot of gear. Once on a whim I took everything out of my trailer and weighed each item one by one (well I measured the utensils as a complete drawer etc) for a total of 263 pounds. So I can see where the OP truly didn't have that much stuff in the trailer.
valhalla360 wrote:
I would be very careful about getting the rig weighed if you don't have to...if everyone is in a pissing match and it shows up over the GVWR, both insurance and manufacture could point to that say it was all your fault.
Getting it weighed is probably a moot point now. But I would still get it weighed so I know what's going on. If for some reason the scale says you are overloaded then throw the scale ticket away and move on.
I always say to add 1200-1500 lbs to the dry weight because you will add more than what you think. Your 263lbs sounds awfully low!
