bobndot
Apr 27, 2018Explorer III
It might be the check valve by the water pump. Try using the pump for awhile it might undo itself. If I remember correctly it was an inexpensive plastic valve that was easy to change.
youtube, will show you how to access it and clean it.
if that does not take care of the problem then the selector you mentioned might be bad.
