wnjj
Apr 28, 2018Explorer II
campigloo wrote:
I think you’re hooked to the wrong inlet. The older trailers have a gravity fed inlet. You just kinda prop the hose up and let it run until it overflows. It was not threaded.
Try moving the hose like pmallone suggested.
I don’t know why there would be a gravity fill if there’s a city/fill valve.
I’m going with the bad pump check valve as is the case most of the time, assuming the city/fill valve itself isn’t leaking.
