alexey75 wrote:
Thank you guys. I will buy some parts in advance and will go to replace just in case it wont fit.
Are you replacing seals and washers every year or just when needed?
Every time you pull the rear bearing out to properly clean, inspect and service it, the seal will be destroyed. If you have the cotter pin style hub, the cotter pin should be replaced. I never had an issue with a washer.
Most bearings available will be made in China and the quality is suspect. If you do need bearings, I strongly suggest that you use Timken brand, I have seen Chinese junk fail rapidly.
