Bumpyroad
May 24, 2017Explorer
rockhillmanor wrote:
And see that tiny drain hose sticking out between the vents?
That is your drain for the fridge. Since it sticks out to the wind and grime of the road it 'will' get plugged up. So put that on your maint. list too! Just find something same size as opening and stick it in there and clean when you see it has stopped working.
be sure when you replace the vent, that you route that drain to the outside.
bumpy
44,066 PostsLatest Activity: May 13, 2026
