oughtsix
May 05, 2014Explorer
NYCgrrl wrote:
I read some of your text and noted you where thinking of using different grades of carpeting throughout your TT. I'd consider other flooring options like sealed cork or a good quality linoleum. Easier to clean, and still good feel for feet with the added bonus of noise control to counteract the unit's metal.
It's great to be able to fulfil a dream and I too will be watching your progress.
I would not use vinyl for the seal layer of your floor. Vinyl is actually quite fragile. Take a look at http://home.howstuffworks.com/home-improvement/construction/materials/marmoleum.htm. It is MUCH tougher than vinyl and very common in commercial settings. You could probably get a remnant piece pretty cheap for the size you need. Go look Marmoleum in a flooring showroom. You will be sold on the toughness when you look at it!
I would also use cork for the finish layer. Cork also holds up very well and is a pleasure to walk on!
