Francesca_Knowl
May 06, 2014Explorer
myrvplans1 wrote:
. Road travel provides a lot of rumbling and that vibration will most likely cause gaps in the floor over time.
Further research on your part would likely reveal that most problems associated with RV flooring are actually related to exactly the materials/method you contemplate: sheet vinyl installed on floors under/before interior cabinetry.
That method is the cause of a major headache for folks in climates where winter temps get/stay below freezing. Pinned by the cabinetry, the vinyl can't expand/contract in response to temperature extremes and will simply tear instead.
Not a pretty springtime picture, but a fairly common one for those with underneath-installed sheet vinyl flooring.
