NYCgrrl
May 07, 2014Explorer
oughtsix wrote:myrvplans1 wrote:oughtsix wrote:NYCgrrl wrote:
I read some of your text and noted you where thinking of using different grades of carpeting throughout your TT. I'd consider other flooring options like sealed cork or a good quality linoleum. Easier to clean, and still good feel for feet with the added bonus of noise control to counteract the unit's metal.
It's great to be able to fulfil a dream and I too will be watching your progress.
I would not use vinyl for the seal layer of your floor. Vinyl is actually quite fragile. Take a look at http://home.howstuffworks.com/home-improvement/construction/materials/marmoleum.htm. It is MUCH tougher than vinyl and very common in commercial settings. You could probably get a remnant piece pretty cheap for the size you need. Go look Marmoleum in a flooring showroom. You will be sold on the toughness when you look at it!
I would also use cork for the finish layer. Cork also holds up very well and is a pleasure to walk on!
:E Thanks for the feedback. I checked into the Marmoleum... first, I think it only comes in 79" roll widths max and I'm not crazy about things that piece together like tiles, carpet squares and wood slats. Road travel provides a lot of rumbling and that vibration will most likely cause gaps in the floor over time.
I am positive marmoleum comes in standard widths. I have laid some that was off of a 12' wide roll. My girl friend insisted on putting it in her place because she had it installed in her day care. I was like "What ever" until I saw it in person, it is seriously heavy duty! Go to a shop that carries it and look for yourself is the best advice I can give. I agree, I don't like pieced together stuff.
I have seen cork flooring that has spent 10 years in a retail setting. It was in great shape! I didn't believe it myself at first. I don't expect you to take my word on either of these, just some suggestions, you will need to do your own research!
My first house I purchased fire damaged. I refurbished the whole house myself with some help from my parents. I used no contractors, mainly because I consider their work very inferior! I have improved every house I have owned since and always complain about the original workmanship. My girl friend has told me several times that I should just build my own place because I am so picky. As tempting as that would be I always tell her I would end up with a 1500 square foot million dollar mansion! Please take this as positive advice from a fellow nit picker, please realize it sounds like you are headed down this same road as my 1500 sq foot million dollar mansion. This is fine, just realize no one else will hold its worth at the same level you do. (Like you infer, people throw away much more money on much more frivolous and stupid things... like gambling)
Glad,oughtsix, better explained the linoleum/Marmoleum options as yes it's composition is quite different from vinyl flooring although they look similar. Just do a google under linoleum and you'll find many manufacturers besides Marmoleum. The flooring comes in sheets of various widths as well as tiles and possibly planks. As far as cork flooring, yep, lots of use in mostly upscale commercial spaces and definitely long lived. The grade of cork used is nothing like the corkboard on your wall, LOL.
Here's an article that explains the pros and cons of linoleum:
http://www.thisoldhouse.com/toh/article/0,,202857,00.html
and here is info on cork flooring:
http://www.houzz.com/ideabooks/1293102/list/Cork-Flooring-101--Warm-Up-to-a-Natural-Wonder
HTH
P.S. OP means "opening poster"
44,071 PostsLatest Activity: Sep 17, 2026
