Dream_Girl
Aug 25, 2015Explorer
Thank you all - very good tips!
Here is a small update:
- The bottom pin at the triangle plate somehow got loosen up to the state it's supposed to be, perhaps because of the towing I did in the parking lot (?)
Also:
All very good point! I will measure, mark and drill the frame to prevent bracket slippage!
Will report back tomorrow.
Also:
3oaks wrote:
When tightening the hardware, always hold the bolt steady with one wrench and turn the nut with another. This will prevent the bolt from acting like a roller sliding the bracket on the trailer frame.
Where ever possible, it is always a good practice to turn the nut, rather than the bolt accept when special purpose nuts are used that bite into the metal.
RDMueller wrote:
... I'll bet that on the side that is loose, the bracket has slipped forward...
handye9 wrote:
Sounds like movement of the frame brackets. They have set screws to prevent sliding. Use a drill to make indentations on trailer frame for set screws to sit in. This will help with the sliding.
