Plumber101010's avatar
May 09, 2015
Help!!! It's hot and have electrical issues :)
Jayco Eagle 318RLS
HAD BEEN HOOKED UP TO A REGULAR OUTLET IN OHIO BECAUSE AC WASNT NEEDED. STARTED TO GET REALLY HOT SO PULLED OUT MY TWO HONDA GENERATORS. HOOKED THEM BOTH UP TOGETHER AND TURN THE AC ON AND EVERYTHING HAS BEEN WORKING FINE FOR THE LAST 48 HOURS.
Sorry about all caps but dictation got stuck. Just now the AC went out. Also lost several outlets as well as the microwave. Both generators are still running and all the breakers are normal. But to play it safe, I flip them off and back on again. Check the fuses and none of them are blown. The only GFI outlet is in the bedroom by the sink.
It appears to be nonresponsive. Meaning the test button doesn't really do anything and either does the reset. I cannot figure what's going on?
