Terryallan
May 10, 2015Explorer II
Plumber101010 wrote:
Sorry, but no one is running an AC off a house outlet. It will throw the breaker. Now I'm not saying someone didn't buy an after market plug in AC that takes less amps like a window unit. That is very possible. But a house outlet will not power a stock AC for a TT that requires 30 amps.
However, you did get me thinking why I spent $2,000 on generators when I could have bought a window AC unit that indeed does run off a stock outlet!!!
Mine does, and has done it for 16 years on 3 different campers. 2 Colemans, and 1 Dometic. IF there is nothing else on in the TT, or on in the house on the same circuit. The House outlet will run it. The AC does NOT pull 30 amps by itself. And not even close to 30 AFTER it is running. It pull the most at start up.
So Sorry. Try again. You will need a HD drop cord, and a HD adapter. As mentioned, the small round ones from Walmart will melt.
44,056 PostsLatest Activity: Dec 27, 2025
