Old-Biscuit
May 10, 2015Explorer III
Plumber101010 wrote:
30 Amp. Can't run the AC off the house outlet, you need 30 amp service to run the AC.
OK.......you are confused.
Your RV is 30A
Open your Main AC Panel in RV.
30A Main circuit breaker with individual 15A and 20A circuit breakers
Your A/C Unit is probably on a 15A circuit breaker
IF water heater and fridge are not on electric and your battery is charged so that converter is not running full out to recharge battery then you CAN run your RV A/C Unit
Just because you have 2 generators doesn't mean you can't overload them.....as you have found out.
WHY? Don't know what/how you are using AC power OR if problem with one/both generators.
And you can put me down in run A/C off house outlet group.
Did for several months on side of house when we sold it---we lived in 5vr cause house was empty. Ran A/C and TV plus kept batteries charged----all from a 20A using our 50A power cord, 50A to 30A adapter and then a 30A to 15A adapter which was plugged into the outlet in garage.
All about energy management
44,056 PostsLatest Activity: Dec 27, 2025
