Kayteg1
Sep 28, 2017Explorer II
I don't think the 250lb campers weight difference will be a big deal, but not only bigger camper will have COG to the rear, but you will need about 2 feet hitch extension what really affects towing capabilities.
In final point that can make load on your rear axle bigger in the range of 1000 lb (if not more -when you load the trailer more up front)
That also calls for SuperHitch.
Would you flat-tow the toad, you would not have tongue weight what makes everything much easier.
