Kayteg1
Sep 28, 2017Explorer II
Ziggy81 wrote:
Flat towing isn't an option since my jeep is wheeled hard and high potential for damage.
The bigger camper 825 is for a short bed truck and the cog will be over the rear axle. The tongue weight of the trailer max is 650lbs but usually less because of how the jeep is loaded on to the trailer. As far as weight goes I'm not far off with ether camper and I agree, 250lbs doesn't make a huge difference.
No offense but from other areas I read about this it seems like it's a knee jerk response that most people have saying I need a 24" extension to tow behind a TC. Looking at the measurements of my trailer compare to the overhang of the campers there's plenty of tongue even with a tight turn. Plus the 825 camper doesn't come down past the bumper to cover the hitch. Obviously not a worry with the shorter 650.
Over the years we tend to forget the things we learn in school, but this is primary school math.
Your original hitch + ball mount will put ball about 5 feet behind rear axle. Knowing the distance between the axles you can calculate how much 650lb on the ball will put on the rear axle.
Now do the calculation adding 2 ft extension.
Sounds like you think without extension your trailer will swing under the camper without interference. That might happen, but next time you put Jeep a foot farther on the trailer and you will have very bad day later.
Or simple doing a turn while crossing a ditch can bring a disaster.
