DoneItAll's avatar
DoneItAll
Help Me Troubleshoot
My 30 amp power cord is tripping the breaker at the campsite. Molded plug is not in good shape, partially pulling away from the cord. Outlet tests just fine. I suspected cord male plug, so I replaced it but now it still trips the breaker. Plug tests open between ground and neutral but grounded between ground and hot. Tripped the camper main 30 amp breaker but problems persists. Since it remains a problem even though I had tripped the main breaker in the camper, does this narrow it down to a bad cable leading into the camper? How hard is this to replace.
John
