Gdetrailer
Dec 28, 2017Explorer III
atreis wrote:
IMO, the more detailed pictures they provide are more useful - the one that shows the reliability/satisfaction scores for various aspects of the vehicle over time. That will let you know that a particular score, for instance, is a result of very low satisfaction with the Nav system (or whatever), but the rest of the car is basically fine.
The detailed ratings on vehicles will also let you see things such as the example from gmw photos - that a car is good for the first 4-5 years then suffers lots of problems. If you only plan to own it for 4 years, you might not care. If you're like me, and want to own it for at least 10 years, reliability as the car ages becomes more important.
Sometimes too many "detailed" pictures (especially when those pictures are intentionally crafted to skew the results) often muddy the water making your job of ferreting out "the best".
Get this straight folks, there is no "best".
EVERY vehicle has some faults where in design shortfalls that make it ugly or mechanical shortfalls which makes it unreliable.
The BEST thing to do is to PHYSICALLY go to a dealer AND DRIVE ONE YOURSELF.
Then YOU can figure out if you like what you see or not.
While you can't "test" reliablity you can get a feel for how well it is put together.. You can listen for noises, squeaks, clunks that may indicate bad assembly.
You can look and feel the interior, the materials and decide if the manufacturer cheaped out and use low quality materials.
None of the above can be assessed from a book.
You can ask other people for their "opinions" but you will get no further and often will make you choice harder. Why, simple, every person you talk to WILL have a DIFFERENT opinion on quality and fit and finish.
I deal with this a lot within my family.. I buy Fords and my BIL buys Chevys.. Doesn't mean his Chevys are junk or my Fords are junk.. It is just means we buy what we like.
There is no shortcuts here, if you want an unbiased opinion you need to to do your own homework (IE YOU TEST DRIVE)not rely on a book or others.
In reality, you have lots of good choices in vehicles, most of the manufacturers of trucks have stepped up to the plate and are delivering good trucks with plenty of HP and towing capacity.
You just simply need to go to each dealer and take a test drive, they don't charge for test drives.
44,068 PostsLatest Activity: Jun 01, 2026
