Huntindog
May 21, 2023Explorer
Cwilson333 wrote:I seem to have overlooked your all knowing recomendations. Fact is you have not made any. All you have is trash other peoples opinions. As soon as I finish this post I will block you. I encourage others to do the same. With no audience you will soon go away from boredum.Huntindog wrote:CWilson wrote:If the only thing I did not like about a TT was the tires, I would buy it.
I looked at a 2021 Grand Design TT and it had OEM installed Lionshead Castlerock China Bombs.
It is literally the easist thing to fix. One could take care of that on the way home from the dealer.
Well that's obvious but when an RV manufacturer decides to install the cheapest borderline tires they can find, and tires are in a location that can easily be seen just by walking up to it, I find it hard to believe they don't also use the cheapest borderline other components and materials in places not easily seen. The Grand stops with the name. There is nothing Grand about them and no better than trailers made by others like Forest River or Thor. If it makes you feel better to believe they're that "Grand", and you somehow purchased a peach that is better than A or B, more power to you but it's only a fantasy.
