MN_Ben's avatar
MN_Ben
Help modifying Bifold / regular door combo for bath
Hey all,
My wife and I do not like the bifold bathroom door on our Lance 981 TC. The bifold feature is a must for getting into the bathroom when the slideout is in, but normal use of the door when the slideout is extended is kind of a pain in the neck.
I would like to modify the door to swing open like a regular door when needed, and be a bifold door when needed.
Here is a VIDEO LINK explaining more. Maybe you can give me some ideas, or better yet, pictures and instructions!
Ben
  • nycsteve wrote:
    I would just leave the original design. Whatever you do wont look as finished as the factory version. I have te same TC , a 2008 and have no issues with the door.
    much ado over nothing, IMHO. still don't understand the issue. would make more sense if it came with a solid door and you couldn't use the john without the slide being out but vice versa??????
    In a TC might not be an issue but in a Class A/C might be a rattling mess when traveling.
    are the original hinges strong enough to support solid door since now the roller takes some of the weight?
    bumpy
  • I would just leave the original design. Whatever you do wont look as finished as the factory version. I have te same TC , a 2008 and have no issues with the door.
  • I can't give you detailed instructions but you could make a door in a door. Just make a swing door and install your bifold door tracks and all inside of it.
