Caveman_Charlie
Dec 03, 2014Explorer II
Cute little RV. I'd be surprised if the fridge works but, it might there are stranger things.
I agree, make sure you have the valve for the propane turned the right way. Open the tank slowly. Fire up the stove first to make sure the propane is flowing well. If the stove works and the furnace doesn't then you have a furnace problem. If the stove doesn't seem to fire up very high either then it is probably the regulator. No matter what make sure the regulator isn't leaking and that the flexible lines attached to the regulator look good. At that age of TT that regulator and lines could be bad and you don't want propane leaking at them.
44,059 PostsLatest Activity: Mar 17, 2026
