drsolo
Dec 03, 2014Nomad
Old-Biscuit wrote:
Light off all 3 stove top burners on high to get propane flow and place regulator in service (establish a demand)
... couldnt do that, could barely get one turned on and lit. Flame was blue and very low. When we turned on a second burner the first one started pulsing and went out.
Stove top burners will give you a good indication of propane flow and regulator.
... so what does it mean? The propane tank is full (it weighs 35.5 lbs)
In some of your pictures you have questions and or ???
The roof vent on left side---that is fridge exhaust vent (lower one on side allows air in that flows upward across backside of fridge and out top) Good air flow draft) needed for proper cooling of fridge
The ?? in side picture (door, stove vent & furnace exhaust vent)
The item in ?? is the door stop/latch. Push door fully open and it will press into round latch on bottom of door to hole it open.
... THANKS!!!
Propane system.....
I would replace regulator and pigtail hoses with new
... will do that.
44,058 PostsLatest Activity: Mar 16, 2026
