RamblinAnne
Jun 02, 2019Explorer
Grit dog wrote:
Unless you know how to repair it, want to tear it apart and learn the quickest and easiest way I surmise is buy a new jack, jack up that front corner and replace it.
Or jack up 2 corners and swap one from the rear.
That’s a bit more risky as I’ve not loaded ours with only 3 jacks. I just know it will float a rear jack regularly and seems to support well that way.
When you say "jack up that front corner", how do I go about doing that? What kind of jack do I need to lift just that one corner? Is it better to just raise the other 3 to get that one off the ground and support it underneath with my telescoping jacks? These things are rated for 6,000 lbs but they scare me a bit. Especially because I have them in their extended-most position.
