AnEv942
Jun 03, 2019Nomad
The TriPod jack mentioned, might be something you could rent or borrow 'possibly' from local RV shop. Rental yard might have something.
Atwood jacks are no longer available, parts increasingly hard to find, no longer made.
Previous Happijac jack models also no longer made with the introduction of the new 4820. Some parts still available.
The new leg, Lippert #736515 (new HJ owners) 'I think', but I'd verify, interchangeable with existing motor, depends on retailers Panther says it will, Tweetys only list new motor as fitting- same part?
Other than trying to fix, replacing just the leg assembly and install existing motor on it would be the least expensive and most expedient. Though Id plan to replace other front at minimum-at least sometime in the near future.
https://tweetys.com/lippert-736515-clutchless-current-sensing-4820-acme-hd-screw-jack-2-800-lbs-white.aspx.
https://pantherrvproducts.com/happijac-4820-736515-rv-electric-truck-camper-loading-jack-leg-only/
