tonymull
Apr 06, 2016Explorer
You should be OK. Center of Gravity might be a concern. You might need some suspension help. Check out torklift. For tie downs too. When you pack the camper put as much weight forward as you can. That will help with COG..and filling the fresh water tank can help as it is usually right at the front of the truck bed. Oh and make sure your tires are inflated to their max. Helps the ride immensely. For bringing it home just inflate the tires and have tie downs installed, you can monkey with the suspension later. I carried a similar camper on a Tundra for a summer. I had airbags. Worked OK. I left my tailgate on but most folks take them off.
44,056 PostsLatest Activity: Jan 12, 2020
