Grit_dog
Aug 04, 2023Trailblazer
ticki2 wrote:
You have a short bed truck with a long bed camper , most likely taking weight off the front axle . Then in addition your putting a 3 ft extension and a 600 lb tongue weight off the back . It’s time to hit the scales , truck axle weights , truck and camper axle weight and if possible, truck camper and trailer axle weights . I suspect you are going to be too light on the front axle and overloaded on rear tires . A WDH will help , maybe enough maybe not . My humble opinion is there is more than one problem to solve .
Not an issue. Even if his camper is far greater dry weight than what he’s claiming for weights, model of truck and lengths.
Do the math and then re-assess what you’re supposing.
And also not discounting that there are additional considerations and/or it’s prohibitive to use a wdh and extension in conjunction in many cases.
44,070 PostsLatest Activity: Aug 06, 2026
