MORSNOW
Aug 05, 2023Navigator III
Miguel951 wrote:
Whoops missed there was already a page 2. Thank you all for the feedback
1) I hear your concern about having too much weight off the front axle. I cant say I can go the scales yet. For now, hoping the airbags will help to keep the stock riding height and weight shifted correctly and the weight-distributing hitch will also help push weight forward. I have all the right wheel and suspension upgrades to stay under limitations and it drives great right now. I will for sure keep this in mind.
2) I can see about using an 18" extension. its actually a 10' floor on what should go on an 8' bed I'm using a 6.75' bed. also carry 1 1/2" plywood sheet running from the length of the bed to help distribute weight better. There's not much weight on tailgate. but will also check this out.
Is a 2.5 hitch with a proper extenion recommended or the truss 2 hitch system? Is the second one overkill?
Your camper is growing... There isn't a 10' long camper made that will fit in a 6-1/2' box properly. It will weigh well over 3,000 lbs with the COG probably over 2' behind the axle, it's just not doable.
