Bedlam
Aug 06, 2023Moderator
Miguel951 wrote:
Bottom outside length of the camper is 10’ top is 17’. I mentioned this was made for a 8’ bed or a 6’ bed with the tailgate down. I have a 6.75’ bed. Dry weight is listed as 2k. There’s no bottom part of camper below tailgate. 28” from truck bumper to bottom of camper.
Campers that are built for short bed applications typically have a CG 2' from the front wall by placing heavier items forward. Most of these campers do not exceed 9' length to keep proper CG.
You are putting too much weight aft of the rear axle and the also adding additional hitch weight on an extension which just leverages even more weight off your front end. This setup will result in unpredictable handling.
