mkirsch
Aug 08, 2023Nomad II
Miguel951 wrote:
Just read that someone didn't recommend a weight distribution hitch for an extension. Interesting. Could you explain? I think I see a reason but just looking to be more educated on this. Is it because it could bend or kink the bar?
A WDH is not an anti-gravity device. It uses leverage to perform its function. Basically it is "prying up" on the rear of the truck. Stuck a bar or pipe or any sort of long lever-like instrument into the receiver, get out on the end of it, and lift up. Same idea.
It all goes back to those lessons you should have gotten in 7-8th grade "Physical Science" class about levers and torques. The longer the lever arm, the more force is applied. A hitch extension is very much a longer lever, and it has to be designed for the forces applied by the WDH.
The Curt/Reese 24-35" extension for 2-1/2" receivers is rated for some WDH (6000lbs), and the Torklift products for sure are. Others that may be out there may or may not be. They might hold up, and they might not. At least if you get one that's officially rated, you can be fairly confident that it's going to perform its function. Unrated there will always be a significant doubt in the back of your mind which takes all the fun out of driving.
