Bedlam
Aug 08, 2023Moderator
I expect the rear of the truck to weigh 2750-3000 lbs unloaded. Your 2003 has the same 9250 lb rated Visteon Sterling 10.5" axle they still use today on the F250, but your brakes are smaller. Your setup is limited by the 7280 lb limit of tires and rims, so you have between 4000-4500 lbs of actual capacity but will be over both RAWR and GVWR door frame stickers.
You still need to put the truck on a scale and measure front axle weight when empty and loaded. This will tell you if the CG of the camper is too far back behind the rear axle. BTW: Both my Artic Fox and current Host are rear heavy if my tanks are empty.
