billyray50 wrote:
Check all the fittings behind the shower access panel. When we took delivery with new Jayco last august noticed little puddle next to toilet and a fitting was loose near back of toilet. Proceeded to check all the water supply fittings in the camper and under the shower fitting was not tight either. It was a slow drip. Under the kitchen sink fittings I tightened also.
Thanks I did check there first under the drain connection is dry aswell as the faucet fitting area is dry. It appears to be running down the wall during showers
