69_Avion
Jan 08, 2014Explorer
Keith Haw wrote:
Thanks for the replies guys. The option of any bigger batteries on the tongue is out. the tanks are as close to the jack as possible and the tank frame is the limiting factor in that direction. The front of the trailer extends out over the battery tray far enough it's hard to even get the box tops on and off, not impossible but not easy. And for that reason I can't go on top of the frame with them, it just wont fit. If I could have made it fit I would have loved to replace the 1 group 24 with 2 GC or group 27 batteries but couldn't so I went with 3 more 24's. I do have 140 watts of solar and a genny but like to watch TV 4 hours or so at night and have a CPAP I have to use all night. I have thought about using some 2" angle mounted under the frame, extending out far enough on each side for them, but not sure of how to attach them without welding, which I don't have access to. IDK maybe mount the angle iron flat side up and bolt it in place then secure the boxes to it. Anyway, I just want it to function and look good to. I'd love to have a single box that houses all the batteries but there's just no way it would fit on the tongue. I've never owned a trailer with such limited space in the tongue area.
Post a couple of pictures of your tongue area to give us some ideas of options. I actually mounted a Torklift box on top of my LP tanks since my trailer is so short and I can add 5 batteries if I want to. The tongue area is the best place for batteries because of the weight.
You would be surprised what you can fit into a tight area.
