coolmom42
Feb 23, 2017Explorer II
I bet there is an electrical outlet on that outside wall near the sofa. You could use a small fan like this O2Cool, with a short extension cord, or run it off batteries. Cut a hole right under the cabinets above the sofa. Frame out the hole and put some trim around it so it looks decent, and just set the fan in it. You would want to be able to take the fan out to change the batteries, if you don't plug it in.
