Newmomat39
Jun 28, 2017Explorer
***Edit*** We have the same 2600tb as the OP. We did relocate the smoke alarm which was not hard wired. And attached a small strap from the inside cabinet to the cabinet door so when opened it doesn't hit the shield.
We just installed a 4ft shield used on a fluorescent light fixture cut down to size. We drilled holes in it and attached it to the ceiling with L brackets. He used a Dremel with a blade for cutting plastic. It does obstruct the corner cabinet door a small amount. But now we have a cold bedroom! You can even close the bedroom curtain and unhook one of the hooks holding the curtain up and still get air blasting in.
