Time4Dirt
Jun 28, 2017Explorer
Newmomat39 wrote:
We just installed a 4ft shield used on a fluorescent light fixture cut down to size. We drilled holes in it and attached it to the ceiling with L brackets. He used a Dremel with a blade for cutting plastic. It does obstruct the corner cabinet door a small amount. But now we have a cold bedroom! You can even close the bedroom curtain and unhook one of the hooks holding the curtain up and still get air blasting in. The end of it does cover the smoke alarm so we will have to come up with a (small door) way to get to the alarm should it go off. But since the same interior air is circulating it shouldn't effect it's performance. But you should check yours if you do this.
What a cleaver idea. Wish we would have thought about that on our first TT.
