lawrosa
Sep 23, 2015Explorer
And actually the payload on the door sticker means nothing... Unless you weigh each truck and compare the axle ratings on the door tags will be the only way to tell true payload..
The ram may have more payload in reality. It just may have a weak link like tires.. Upgrade the tires maybe and youll be fine..
But we need hard #'s and this is an assumption..
Need scale weights
Door tag axle ratings
Tire max psi and lbs on sidewall..
You probably have an plenty of of payload left...
Need scale weights
