KD4UPL
Aug 25, 2017Explorer II
Why would you disconnect the 58 watt panel? You might as well use it if it's mounted there. Or, did you mean you will completely remove it?
As for the wires, it doesn't matter what they are for. You just need to hook all the negatives to a #6 or maybe a #4 and run that to your new batteries. Same with the positives, connect them all to one large #6 or #4 and hook that to the new batteries.
