dave17352
Aug 26, 2017Explorer II
work2much wrote:
I would just test out the lines with a voltmeter and abandon any prewiring for solar or anything else you aren't using. Extra wires here at battery aren't for fridge or any other normal camper function. Run a new pair off the roof of correct sizing with your new panels through a new charge controller to the battery bank. You will need a good volt meter at least to monitor states of volt levels to keep battery bank from over discharging .
I would not be sure they could not be for any other normal camper function.
