neschultz wrote:
Yours looks like the one our Via came with. On ours, you had to unclip the top cover (two at bottom left & right corners and one in top middle). Once that is off, there are 4 small Philips screws holding the clear cover on and the bulb can be changed. We replaced our whole light with a motion activated Starlights SL1000 LED one that we like much better.
So you have to take off the silver looking part before you can remove the clear part? I have been trying to remove the clear part thinking the silver part was a permanent item. I will see what I can do when I get home from work today.
Also I am very much interested in that replacement fixture you mentioned. Was it hard to replace the old one?
Thanks for the help.
Del
